![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 Sucker |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Father Xmas has given me a sucker.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
surely a colonoscopy would be better at a hospital!! |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Nino,
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
Nice one BB - they are brilliant. Changing oil on any of the families cars is so simple now and as you say with the opie oil discount oil changes are cheap!. Ade. 405 AB exec seats Baltic and Cirrus
| SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114
So stupid question time, I take it without the dipstick on the 2011 you will be going in through the oil filler? Take it you can still get all the way to the bottom with it? |
Sucking the old oil out is simple.
Excellent, thanks for the quick reply. I may look at one for the future, as I would like to change the oil every few months/5k ish myself. I am with you on the old and bad back part |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
Simbad... Pretty much the only way to change engine oil in a 2011 & newer FFRR is to suck it out... Its how JLR designed them all now a days |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Excellent machine , 115 stg , well worth it 2015 4.4 AB
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Thought I'd remembered an old thread on draining vs sucking and found this:
. Thoughts? Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Greg,
Greg, first time I changed oil in my car was like that, bit messy, then i realise that the same pipe i disconnected to drain oil is the pipe you hook up the sucker to extract oil, soo same thing - you get same amount of oil out either way. i do drain oil from the small pocket above crossmember (every 3d oil change).
Sure - seems like there are benefits to sucking.
| All times are GMT |
