Home > Technical (L322) > Have A Donor 2005 L322.
desertdude
United Arab Emirates 2003 Range Rover Vogue 4.4 V8 Alaska White
I have a 2005 the BMW to Ford conversion year with the BMW motor car with a knackered motor ( Dont have the funds nor interested in bringing the car back to life ) Now this has the MOST system was wonder how hard (or even possible ) would it be to transfer the ICE system, including GPS and bluetooth over to my 2003 L322. Would I have to strip the entire car for the fiber optic wiring or is it possible just to swap over all the modules, I took out the navigation DVD in the for sure all the connectors are different, even the way its fitted on the car is different.
So anybody done this before, I've trawled the interwebz but haven't gotten much info regarding this.
Post #462345 27th Dec 2017 6:31pm
holidaychicken
I have been doing a fair bit of work on a 2006 facelift touch screen model with the BMW TD6 engine and half and half electronics and it’s a pain as it doesn’t seem to follow either sets of rules.
All I can say is good luck if you manage it, I have had issues with programming new keys, trying to self test the instrument cluster, pairing immobiliser ECU from the new system to EMS from the old BMW setup and connecting up my Faultmate has been a Censored trying to decide which modules from the old system and which from the new system I need to communicate with the various ECUs.
Sorry, that wasn’t much help Sad
Post #462403 28th Dec 2017 3:59am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Not worth the cost or hassle imo , not that good a system , better to upgrade the 03 i reckon
Post #462415 28th Dec 2017 10:29am
mjdronfield
Sounds easier to swap engines and get the 2005 going.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #462448 28th Dec 2017 2:15pm
