![]() | Home > Technical (L322) > No sound |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I wouldn't be surprised if it's not water ingress again in the rear left hand compartment as viewed from behind. 2010 Disco XS TDV6, 2009 Freelander 2 GS
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 ![]() ![]() ![]() |
Must admit I thought that too, I’ve had a good dig around in there and it’s bone dry, not even any signs of water ingress, looks like I’m going to have to start tracing wires! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
i entered 'no sound' into the search and 7 pages of threads came up with some relevant threads in there... ... - .- -.
Sounds daft but this happened in a Jag "R" and was cured by disconnecting and then reconnecting the battery. This resets all the ECU's and other gizmo's. Let the Sat Nav close down properly (5 minutes) before disconnecting the battery though and when reconnected remember to do the suspension reset by turning the wheel to full lock on either side.... |
you might be correct gary....the RR has so many ecu's that logically one or two are going to need a re-boot sometime or other .. ... - .- -.
when I did a post mortem on my mk III nav the water was only evident on the board as very clear mass of oxidation akin to pidgeon poo visually. 2010 Disco XS TDV6, 2009 Freelander 2 GS
makes sense cos it only needs a little bit of water to damage the electronics and any moisture on the surrounding area might have evaporated... ... - .- -. Y. O. L. O. . |
Tried the hard reset (battery disconnect) and the dealer has changed all the components, amp, phone, tuners and infotainment module, even software update, they say that although everything is working properly something is preventing them from talking to each other correctly they think a wire may be chaffed or broken somewhere in the system, I’ve had a look today and although some are badly routed (around sharp edges and so on) none seem damaged, got a lot more to check though, will take some time I suppose, at least I’m forming some sort of bond with old girl!!!! |
strange one this, let us know if you find anything.. ... - .- -.
Scarey your avatar takes up a sh*tload of potential text area mate.... |
so does your signature gaz... |
Have you seen this?
No scarey it DOES NOT
touchy gary.....i've condensed myself.... ... - .- -.
