![]() | Home > Technical (L322) > Probable belt failure - looking for procedure/advice |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2752 ![]() ![]() |
The squeaking is likely to have been caused by a failed tensioner or idler pulley bearing. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Download rave from the Wiki http://www.fullfatrr.com/wiki/Main_Page
Sennokian Member Since: 15 Sep 2017 Location: South East Posts: 4 ![]() ![]() ![]() |
The belts are off. Can’t tell at the moment if they’re damaged, but let’s face it...
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Very easy to do on the drive - just look at the wiki and make sure you have the right tools to take off the viscous fan.
remove Fan (don't need to remove the rad) - do need special spanner and holding tool ideally _ apparently has been done by passing the belt over the fan but all i can say to that is good luck |
