Home > Technical (L322) > Alarm siren location
Haighy2
Hi ppl, I have done a quick search and not found an answer,,,
My alarm went off earlier (2004 vogue) but there was no noise, just flashing hazards,,, can anyone point me in the direction of the siren so I can try a replacement as I would like to have it working if possible
Thanks
Ian
Post #464076 10th Jan 2018 10:18pm
as you look at the engine from the front, its at the top left. ... - .- -.
Post #464080 10th Jan 2018 10:27pm
Haighy2
Ah damn, just had a look and I have found a decent length loom with a black 4 pin plug on the end but can't see a siren,,,,,, 🤔 ebay I recon and get one plugged into the loom, see what happens
Post #464083 10th Jan 2018 10:48pm
have a look at the WM , its bolted on a bracket and its called a BBUS or something like that.. ... - .- -.
Post #464084 10th Jan 2018 10:52pm
Haighy2
WM??? Im at a loss as to what that is,, sorry
Post #464088 10th Jan 2018 11:02pm
holidaychicken
I'm guessing Workshop Manual and Battery Back Up Sounder
There is a metal box with a nut on top which is where the sounder is bolted inside and then the metal box is held closed with another nut or two and fixed to the inner wing area by the bonnet hinge
Post #464097 11th Jan 2018 12:20am
Haighy2
Cool, thanks, I'll have another good look tomoz when it's daylight 👍 2004 java black 4.4 v8 overfinch
Post #464099 11th Jan 2018 12:24am
Haighy2
I'm assuming my siren is definitely missing? 2004 java black 4.4 v8 overfinch
Post #464152 11th Jan 2018 12:56pm
should look like this,
Post #464167 11th Jan 2018 3:12pm
Haighy2
Definitely not got anything like that, the plug Iv found looks right for it though,,,, I'll oder one and see how I get on 👍
Thanks 2004 java black 4.4 v8 overfinch
Post #464168 11th Jan 2018 3:26pm
