Home > Maintenance & Mods (L322) > Air con condensor
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Air con condensor
I need to have a new air con compressor fitted to my 2011 4.4. Is it normally necessary to change the condensor at the same time?, or would giving it a good clean up if it is not damaged be ok?
Post #507763 7th Mar 2019 1:05pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Mine wasn't touched when my compressor was replaced. 2 yr warranty too. 2010 4.4 TDV8 Vogue SE
Post #507794 7th Mar 2019 4:08pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
As long as the system is vacuumed out properly before refilling, I don't believe it is necessary. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #507833 7th Mar 2019 6:00pm
