![]() | Home > Technical (L322) > HELP - PLEASE |
colinwebster Member Since: 19 Dec 2017 Location: Devon Posts: 43 ![]() ![]() ![]() |
Hi All,
The battery is Brand New at 12.8 volts (It's a month old) |
Do a hard battery reset, Disconnect the live & earth and touch them together... |
Thanks.
MM, after a while the alarm has gone off again, I noticed the front air suspension lifting at the same time, none of the other faults this time??????
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35846 ![]() ![]() |
the bonnet switch is a common problem, clean it or disconnect it..... ... - .- -.
Thanks Stan, the switch was disconnected when I bought the car, its still disconnected now, but it is in the area where the windscreen guys were ??? |
you didnt mention the windscreen replacement in your original post..
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
If it's just had a windscreen fitted I'd be starting there.
Hi Stan,
There's loads of wiring running up both a pillar trims and there's also quite a few running to the light / rain sensor at the top of the screen and also running to the rear view mirror |
"Its been perfect up to now, but had a screen fitted yesterday??" was in the post.
Really Stan!! It was there probably edited some other grammar. |
I think you have mis read my post Stan,"Last edited by colinwebster on 20th Jan 2018 2:50pm. Edited 1 time in total" your reply was after 1600 hours so unless I'm mistaken the reference to the windscreen was in the original post. I have been a moderator on many forums over the years so Ill put your mistake down to professional pressure |
