Home > Technical (L322) > Lumpy running
j_rov
Lumpy running
I’ve started getting lumpy running like a misfire upon startup and until warm most times i start up including warm and cold starts.
No faults showing on dash or iidtool
Initially I’m thinking could be EGR so ran around with live values for a bit and note the % fluctuates but not sure if that’s normal or not. Left and right are not showing same value all the time.
I’ve read possibly a glow plug but not sure how that can be as it starts up fine.
The problem is mild in neutral and shows more when in gear.
Any ideas?
Thanks __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #465748 23rd Jan 2018 9:06pm
rar110
What model L322? ______________________________
Post #465751 23rd Jan 2018 9:10pm
i'd check them hose's Thumbs Up ... - .- -.
Post #465753 23rd Jan 2018 9:14pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
10 plate tdV8 according to his sig
Post #465754 23rd Jan 2018 9:14pm
j_rov
Yes, 2010 MY L322 3.6 TDV8
Hoses seem all fine... __
Land Rover History:
1976 Series 3 2.25
Post #465759 23rd Jan 2018 9:26pm
j_rov
Also, problem disappears under hard acceleration... but is pronounced under idle and very light throttle. __
Land Rover History:
1976 Series 3 2.25
Post #465761 23rd Jan 2018 9:31pm
j_rov
Anyone else have ideas on this?
If not, i’ll recheck every hose this weekend! __
Land Rover History:
1976 Series 3 2.25
Post #465926 24th Jan 2018 11:08pm
miggit
Whistle Hate to say it, but that sounds like some unhappy injectors... But I could still be suffering from Roverphobia Sniggering Yesterday I couldn't spell Engineer... Today I are one!
Post #465984 25th Jan 2018 2:37pm
Paul thornton
Sound like an injector fault to me.
Have you had a look at the live values or done a leak off test?
Post #465987 25th Jan 2018 2:46pm
j_rov
I'll get it booked into a specialist then!
It's intermittent which is why i didn't initially think injectors. Today for example it ran perfectly well. __
Land Rover History:
1976 Series 3 2.25
Post #466001 25th Jan 2018 4:36pm
Paul thornton
My TD6 had I very occasional lumpy tick over which gradually got worse to the point it was doing it all the time.
Turned out to be an injector fault.
Post #466005 25th Jan 2018 5:38pm
miggit
If your car is reasonably low mileage then you could try some injector cleaner, but if it's anywhere neer 100k +/- 20k then I'd suspect the injectors could do with a deep clean and testing on a test rig. If you're not doing the removal yourself then I'd suggest either a trusted indy, or a Bosch Service Centre..... 2 reasons for this, you'll save on the labor and importantly the Stealers will not fit recon injectors, they'll just replace with new and charge you the equivalent of a full clean and test by the diesel specialist per injector...... so if you want to pay up to 8x too much you know where to take it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #466079 26th Jan 2018 11:16am
Don’t be too hasty removing the injectors either as the seals and pipes need replacing each time they are removed and that adds up too!!! £100 ish each cylinder springs to mind, but it has been some time since we last did some... Neutral
Post #466081 26th Jan 2018 11:32am
j_rov
Specialist found 3 injectors well out of tolerance and are changing them as I type. __
Land Rover History:
1976 Series 3 2.25
Post #466617 30th Jan 2018 5:06pm
miggit
Whistle No wonder it wasn't happy!
It'll be a new beasty when you get it back Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #466672 30th Jan 2018 10:30pm
