![]() | Home > Technical (L322) > Lumpy running |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
What model L322? ______________________________
i'd check them hose's |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
10 plate tdV8 according to his sig |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389
Yes, 2010 MY L322 3.6 TDV8
Also, problem disappears under hard acceleration... but is pronounced under idle and very light throttle. __
Anyone else have ideas on this?
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
Sound like an injector fault to me.
I'll get it booked into a specialist then!
My TD6 had I very occasional lumpy tick over which gradually got worse to the point it was doing it all the time.
If your car is reasonably low mileage then you could try some injector cleaner, but if it's anywhere neer 100k +/- 20k then I'd suspect the injectors could do with a deep clean and testing on a test rig. If you're not doing the removal yourself then I'd suggest either a trusted indy, or a Bosch Service Centre..... 2 reasons for this, you'll save on the labor and importantly the Stealers will not fit recon injectors, they'll just replace with new and charge you the equivalent of a full clean and test by the diesel specialist per injector...... so if you want to pay up to 8x too much you know where to take it |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Don’t be too hasty removing the injectors either as the seals and pipes need replacing each time they are removed and that adds up too!!! £100 ish each cylinder springs to mind, but it has been some time since we last did some... |
Specialist found 3 injectors well out of tolerance and are changing them as I type. __
