Home > Technical (L322) > Starting Issues
C7
United Kingdom 2012 Range Rover Vogue 4.4 V8 Bonatti Grey
Starting Issues
Sad My TDV8 has decided it will only start intermittently. Even after a long run it might or might not start. It gives a "click" as if the battery is dead, then might start after two or three tries. Jumping it always starts it, suggesting the battery is the problem, but it can be fine for days then suddenly will not start. Local garage (not RR specialist) can find nothing wrong with the battery or electrics.
Anyone any ideas?
Post #466489 29th Jan 2018 5:16pm
millerj90
I had a problem with a starter motor that did exactly that. Wouldn’t start, hook up the jump pack; and away we went.
Turns out it was nothing wrong with the electrics, and hooking up the jump pack only gave time for things to "settle". I think I read another post on here that had exactly the same problem.
Post #466490 29th Jan 2018 5:26pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Sounds like the usual tdv8 starter problem. had mine replaced under warranty and no problem after. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #466492 29th Jan 2018 5:33pm
Possibly also a loose connection onto the battery.
I had this a few months ago and the car would appear totally dead, or just click, then a wiggle of the earth connection would sort it out. Worth giving them a tighten. Got - 2017 SDV8 Autobiography in Loire Blue
Post #466494 29th Jan 2018 5:55pm
C7
Yes, I had a starter motor replaced when the car was about six months old with a similar issue but this is far more intermittent, and always works with the jump pack.
Post #466495 29th Jan 2018 5:56pm
CS
I had similar, intermittent non-starting, initially no click when starter button pressed, but after a while it started clicking, battery fine, was defective starter motor, it was replaced and now fine again. The problem seemed to involve the motor overheating. If you got a new motor in 2012/13 it may have become similarly defective. Only Range Rovers since 1988
Post #466496 29th Jan 2018 6:06pm
Sandyt
I have a petrol but had a similar problem with my supercharged replaced the positive lead and problem solved - sometimes the leads corrode internally also worth taking both terminals off the battery cleaning and reseating so they are tight - could be poor connection and putting the jump pack on makes it good
Post #466502 29th Jan 2018 7:07pm
