Home > Technical (L322) > Air conditioning compressor fault
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Hoping someone might be able to help, please.
My air conditioning gradually lost its effectiveness over a couple of weeks.
I’ve had the system checked and there are no leaks.
My IID tool shows HP pressure between 11 and 13 bar. Usually stable between those pressures, so I’m guessing the variation is just dependant on ambient temperature as I’ve been checking at different times of the day.
I did notice a slight increase in HP when I pressed the “program” button.
Also little change in pressure when I stop the engine.
I can visually see the compressor clutching in and out when switching the AC on/off.
Sooooo, finally the question......
Is the compressor kaput? Seems to me that the swash control has failed.
Just would like a few opinions before I throw parts at the car. 2007 3.6 TDV8
Post #467754 8th Feb 2018 12:42pm
TaylorM
Australia 2007 Range Rover Vogue TDV8 Buckingham Blue
Mate how did you go with the AC - seems i am having similar trouble down here in NSW...
Post #499994 29th Dec 2018 2:05pm
cheezels
Replaced the compressor in the end. Got a rebuilt one from Duckworths.
There is a solenoid inside the compressor that controls its loading and this is what fails.
I still have the old compressor (supposed to send it back for core refund, but haven’t gotten around to it) and it can be repaired with a new solenoid, which I’m fairly confident is this one
https://www.polarbearinc.com/index.cfm/product/405/ex-10067.htm 2007 3.6 TDV8
Post #499996 29th Dec 2018 2:23pm
