![]() | Home > My Range Rover > 2010 FFRR conversion with 24's. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Not in a million years but we can dream |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
Nick i had 24s on mine a couple of years ago but couldnt cope with ride
Cheers |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I have to say, I've never been a Porsche fan, but that does look quite tasty. |
Must admit miss walking out to be greeted with this |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1530 ![]() ![]() |
Gadzooks! What section tyres on the porker??
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Is that a 996 converted to a 997? |
Tis indeed. Not one of my most sensible decisions as did full (front and rear wings etc) conversion using original porsche parts (no cheap fibreglass kits). A bit more complicated to do than first thought. The tyre profiles were 275/25/20 on back and 255/25/20 on front IIRC.
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Hi im intrested in the carbon wrap can you give any tips and where did you get it type ect
Got mine of ebay. Lots of different sellers. Its called 3M carbon di-noc and from what i've read is considered the best quality stuff. I've just bought some in silver carbon to wrap some interior bits. There lots of videos on you tube showing how to use the stuff but basically you lightly heat it and wrap it around whatever your covering. Its relatively easy but can take a couple of attempts sometimes so buy more than you need! |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
this carbon stuff will only look acceptable on a black RR me thinks... ... - .- -. Y. O. L. O. . |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
There's one more thing you need to do externally to get the 2010 look- change the C pillar trim. Yours is the wide one. Later models don't have it. It went in 2005/6 I believe. I'm sure someone will confirm or correct that. It has been discussed here before. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Royle Member Since: 12 Nov 2010 Location: Perth Posts: 655 ![]() ![]() |
I was thinking the same thing. Remember seeing this while browsing - http://www.fullfatrr.com/forum/topic1520.html
