Hello dear friends!
Immediately apologize for the English language. I'm from Saint-Petersburg, Russia. I bought a Range Rover 2002 model year, the engine M57. The price is 7900 EUROS. Interior-light materials. Such color materials a rare, usually gray color of. Heated steering wheel, heated all seats. Roof hatch. Not enough for a complete set of good multimedia system. There is a simple radio with a monochrome display.
What to do with FF:
1) in the air suspension water. It is necessary to remove the receiver to drain the water. Blow out the system, change the dehumidifier (silica gel).
2) Change the fuel gauge in the auxiliary part of the fuel tank. He's not working right now.
3) to Change the Parking sensor rear
4) Change some suspension parts, rubber parts.
5) Wash the interior parts, some replace.
6) re-Covered armrests in the front doors.
7) it is Possible to replace the front seat covers.
What's done:
1) Replaced front left drive shaft. There was a backlash in the internal CV joint. And seal replaced. Ordered on lrdirect
2) Replaced the front lever Assembly with ball bearing. Lemforder
3) Varied on the front caliper hose and fitting for the flow of brakes. The previous owner why it is not correctly mounted, these parts.
4) Replaced the actuator lock the lower hinged doors B/y from the scrapyard
5)Replaced the gas stops of the tailgate. Lesjofors 81 757 18
6) I Bought caps on leashes of wipers BMW 61617037356 . The leash of the janitor is installed from BMW E60
7) Installed BOSCH aerotwin wipers from Bosch BMW E60 3397118955
make a copy of the ignition key-found from BMW, works just fine. The old key was not given the desired frequency of 433 MHz, in the end do not work
9) I Bought a diagnostic universal OBD scanner, EasyDiag - without it it is difficult to be friends with this car.
10) In the process of repairing the rear centre stop signal. Installed in the case of the Board from the stop signal Toyota.
11) Detail wash car!!
A little different photos:
 | | Click image to enlarge |
