![]() | Home > Technical (L322) > Heating - Really Hot or Really Cold |
| ppceuro Member Since: 26 Feb 2022 Location: Derbyshire Posts: 9
Just bumping this...
| kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85
I have this same feature with mine. Not sure if it is stuck duo valves. Heat turns cold when both temp knobs are full cold. Electric water pump stops then so it could be pushing coolant through swollen gaskets in duo valve or something like that. Duo valve is not easily accessed in tdv8 so I have kept turning knobs. 😁 -08 3.6 Vogue
