|  | Home > Maintenance & Mods (L322) > Torx socket sizes? |
| Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35      | I bought a US Pro branded 17 piece impact set covering E5 to E24 for under £25 last year.
|  27th Feb 2018 10:51pm |
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344    | When you say Torx bolts, are they 12 pointed bolt heads rather than torx? If so, a normal socket (12 pointed obviously!) will fit.
|  28th Feb 2018 2:47pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | These are the sockets I think I need (but not sure about sizes)
|  28th Feb 2018 3:45pm |
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492      | A 12 sided socket might welll do the trick if you have some to try. Failing that you can get female torx socket sets with most sizes on amazon for a few £'s normally going up to e24. Current 2007 TDV8 Vogue Buckingham Blue | ||
|  28th Feb 2018 5:08pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | This is the seat bolt.
|  1st Mar 2018 7:12pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | I ordered a set of torx sockets.
|  4th Mar 2018 3:37pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | yep a standard socket will fit, but you wont be able to put the same torque through the bolt as a E socket.
|  4th Mar 2018 6:02pm |
| Posting Rules
