Home > Technical (L322) > Running problem
Foxy
United Kingdom 2004 Range Rover SE Td6 Adriatic Blue
Running problem
Hi
I have an old 2002 L322 TD6 , which judders upon acceleration , and general running at 45mph or over - Any ideas, what causes this?
Post #471391 6th Mar 2018 8:47pm
welcome,
use the search function and put in cattle grid, judder, etc. theres plenty of info on here.
I would hazard a guess that you are seeing the first signs of your gearbox going south. it usually the torque converter from memory which causes these symptoms but have a search as theres loads of info on it and its a common problem, if not a cheap one to sort out. There is nothing that can't be fixed with a hammer😜😜
Post #471395 6th Mar 2018 8:56pm
could be the above or the injectors need replacing.. ... - .- -.
Post #471399 6th Mar 2018 9:00pm
Foxy
Thanks I'll start researching. - not sure the cars worth it though.
Post #471401 6th Mar 2018 9:06pm
