![]() | Home > Technical (L322) > Analog Clock time adjust?? |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 713 ![]() ![]() ![]() |
The analog Clock (in the lower front centre section of the dash below the heater controls ) reads wrong on our 2006 TDv8.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
You change it from the central screen with the sat nav etc... in it and they should both change. Change the time to something made up and then set it correctly again and see if they sync.
You're a star & I think that probably does count as embarrassing - I should have tried that previously - lol. Quite satisfying to see the hands on the analog Clock whiz forwards, then backwards when I adjusted it! Now all in sync. Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8115 ![]() ![]() ![]() |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 110 ![]() ![]() ![]() |
My analogue clock doesn't work either (new to me 2007 tdv8 Vogue) even though I've corrected the time on the screen. I suspect the clock itself is broken but before diving into a used replacement I'm wondering if there are any known issues or tricks. I've looked for fuses and read everything I can find to no avail. I've not pulled the panel out as yet but I can't imagine it to be as simple as it not being plugged in!
