![]() | Home > Maintenance & Mods (L405) > Help on wire that triggers high beams |
| Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268
If it's only on FM then that is likely standard un-shealded cable interference. If it's digital DAB it could be the LED frequency. I don't have the same issue luckily, however, if I plug in a usb charger my DAB drops out? Strange...
| Trebaix Member Since: 17 Feb 2015 Location: Leics Posts: 24
They are 65 watt LED’s that can be selected to come on with main beam via on/off switch in cabin. Switch is just above drivers side air vent. I am just south of melton so probably not far.
I'm also south of melton!
I find the standard lights are fine on dip but on main beam I prefer something that Has more depth of throw. As a reference I used to use cities Super oscars and these LED’s are much more powerful with their throw of light. I have sent you a private message.
