![]() | Home > General (L405) > 2016 TD6 common problems |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
So I will probably in the market for a 2016 fullfat td6 in about 2 years. "Upgrading" from my 2004 fullfat 4.4. What are the issues to prepare for with this model. Only thing I found from car and driver review was the electronics. Are the that abysmal and are they correctable/upgradeable? It will have in the neighborhood of 100k miles +-. Thanks |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
Live in the states and want the TDV6 ? Get a petrol as DB says . TD6 , some have suffered crankshaft snaps |
Oh crap. You are bursting my balloon. I wanted that range rover feel with 30mph US. |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I actually have the 2016 MY L405 with the 3 litre diesel and am very pleased with it after 33,000 miles. No problems, very smooth (probably smoother than the v8 ) and more than enough power; and ours spends a lot of time towing horses about. |
No electrical gremlins? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Yes, that's about the TD6's maximum speed. ![]() |
The electrical socket for the tow hitch was faulty on delivery and the onboard service due indicator does not work correctly. There is a fix but I can't be bothered to take it in. Otherwise all good. |
Oops. 30 MPG. Although I do drive like the boot is full of nitroglycerin. |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
Same here 2016 model with 30k miles....no issues at all engine wise. Only 1 problem when the tailgate lost synch but that could happen to any L405. 2021 L405 Vogue D300 2016 L405 Vogue 3.0TDV6 (Sold) |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1422 ![]() ![]() ![]() |
Search on here for threads about TDV6 engine failures/seizures and there is a current thread about engine oil being diluted with diesel leading to reduced service intervals/engine wear. Maybe also look at Discovery and RR Sport forums, that engine is used very often in those applications, though I recall reading that the less spacious engine bays there might cause more problems than in the 405. Only Range Rovers since 1988 |
The TSB seems to imply it was a rare event from improper factory install of the bearings. I would assume if it hasn't broken by the time it hits 76k or more, when I'd be looking to buy, it's not one of the problem motors. |
