Home > Technical (L322) > Start Button not responding
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks..
Came out to do the school run.. started fine no prior warning.. parked up and picked up the wee won. Now the Start button would not respond at all. The button was previously cracked and was replaced 2 months ago and it's been running fine with no issues.
Is there something else I need to look at? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #476822 26th Apr 2018 4:24pm
j_rov
Does the TFT screen show the image when you open a door?
Is it showing any messages like cannot find smart key? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #476824 26th Apr 2018 4:39pm
if you have all electrics working then it could be the starter motor...keep pressing the button hopefully it will fire up.. ... - .- -.
Post #476825 26th Apr 2018 4:50pm
scotcruz
The TFT brings up Range Rover icon and nothing on the cluster.. just the mileage and date. Current:
Past:
Post #476826 26th Apr 2018 4:51pm
scotcruz
It not bringing up the other light one the cluster that you would normally get when the ignition is on the ON position. Looks like another gremlin unless someone experience the same issue and knows a solution.
I have read on various posts that folk have left the motor locked for few hours and been fine after that. Trouble is I am outside the school and csnt leave the car here..
Going to disconnect the battery and see if it helps Current:
Past:
Post #476828 26th Apr 2018 4:58pm
good plan...consider a flat/faulty battery as well... ... - .- -.
Post #476829 26th Apr 2018 5:00pm
j_rov
was just going to say "think flat battery".
Does the car lock and unlock at the "normal" speed?
If you can disconnect battery and reconnect where you are, try that. __
Land Rover History:
1976 Series 3 2.25
Post #476833 26th Apr 2018 5:12pm
scotcruz
Yes lock and unlock fine.. now getting "Low Battery - Start the Engine".. so may be battery related..
Just checked the boot and I dont have the 10mm key so I am goosed.. all those 10mm key jokes have hit me like karma lol..
So called AA.. Will report back Current:
Past:
Post #476835 26th Apr 2018 5:17pm
j_rov
Hope they get to you quickly and it's something simple. __
Land Rover History:
1976 Series 3 2.25
Post #476836 26th Apr 2018 5:19pm
scotcruz
I hope so.. fingers crossed Current:
Past:
Post #476837 26th Apr 2018 5:22pm
scotcruz
$loody Gremlins.. wish I had my 10mm key !!
AA guy comes.. connects his battery boost.. nothing happens.. Then connects his jump leads to the van.. again nothing happens.
I says do you want to try doing a battery reset.. He goes aye that's a good idea. Does the battery reset. 10 mins later connects it back and puts the jump leads on. RR starts in a flash.. Wait for this... the funny thing is that the jump leads were not even connected to the van Laughing Very Happy
Bizarre how it was reacting. Especially when I had the Battery Low - Start the Engine error Current:
Past:
Post #476846 26th Apr 2018 7:54pm
kgeddes
Glad you got it going Thumbs Up
Did the AA man say what caused the problem?
What is the 10mm key you refer to?
Thanks
Post #476888 27th Apr 2018 9:27am
the battery low error probably was a result of you constantly trying to start the FF..i reckon its the starter motor.. ... - .- -.
Post #476889 27th Apr 2018 9:30am
scotcruz
Kgeddes.. the 10mm key is a forever running joke which is you never find one when you need one. If I had one in the car.. I would have reset the battery myself and would have been on the go rather than waiting for AA.
The AA guys didn't have a clue and was ready to tow me until I said reset the battery.
Stan.. I hope it's not the starter motor Big Cry Current:
Past:
Post #476914 27th Apr 2018 12:23pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Could one of the battery terminal connection have been loose which was solved when he did the reset and tightened it back up? Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #476920 27th Apr 2018 1:29pm
