Home > Technical (L322) > C1A13-64 Suspension working intermittently
sm123
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi there, had the 2012 4.4 Westminster throw up a few issues recently. The suspension is working most of the time but occasionally says ‘drive moderately suspension fault’
I’ve put it on the computer and it’s given C13A13-64 PRESSURE DOES NOT DECREASE WHEN VENTING GALLERY
C1131-92 AIR SUPPLY
Been told it’s the compressor but I doubt this is true as it works most of the time.
Any help would be greatly appreciated 👍🏼
Thanks. Sam
Post #478034 11th May 2018 3:00pm
check the filter isnt clogged up and spray some soapy water onto the compressor air tank...you might have a faulty one.. ... - .- -.
Post #478039 11th May 2018 3:14pm
sm123
Thanks. I’ll try this asap
Post #478041 11th May 2018 3:56pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Try running for a while with the bronze silencer removed (fitted on the exhaust side of the system and located under the compressor cover)
If it is clogged it will increase the vent time and may cause the alarm you’re getting.
I had a similar issue and drilled a small hole in it 2007 3.6 TDV8
Post #478103 12th May 2018 12:04am
