![]() | Home > Technical (L322) > 4.4 petrol v8 torque converter question |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1021 ![]() ![]() |
Your lock-up clutch has three modes of operation: 1) off, 2) controlled slip and 3) on
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
Hi Phil thanks for the detailed reply, do you have any links or contacts for reputable companies where I can get a decent reconditioned unit from?
The Sachs WA4/W260 S-2GWK Type F38 torque converter used in the Range Rover 5HP24 transmission features a captive clutch, which means the spring abutment for the LUC piston is friction-welded in position during manufacture. This weld has to be machined away to remove the piston and replace the friction plate and then accurately re-welded back into position afterwards. This is quite a specialist task, so I would recommend that you only use a ZF-approved re-manufacturer with known capability, such as JPAT (https://jpat.co.uk/torque-converter-remanfacture.html), Sussex Auto Parts (http://www.sussexautos.co.uk/torque-converters.php) or John Mackie’s (http://www.mackie-transmission.com/index.php/en/).
MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 44 ![]() ![]() ![]() |
Hi Phil and forum,
The only certain way of determining if it’s the torque converter lock-up clutch causing the issue is through the use diagnostics to measure & record the engine speed and turbine speed and then to compare the two.
Thanks Phil.
