Home > Maintenance & Mods (L322) > hatchback button
steve1
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
hatchback button
Just a quick question, when I press the button on the key fob to release the hatch lid is it supposed to completely release? ie after pressing the button on the fob I still have to press the microswitch to release the hatch which makes pressing the fob pointless!
Post #478029 11th May 2018 12:57pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
I think that the idea of the key switch is so that you can put shopping into your boot without unlocking the rest of the car - once pressed you can open the boot but when you close it - it re-locks, no other lock is opened.
Post #478033 11th May 2018 1:58pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
On my 2011 model, I'm pretty sure pressing the fob button releases the upper tail gate, and I just pull it up. No need to press the upper release button. As Bruno points out, it only unlocks the tailgate though, not the rest of the doors, and the tailgate is re-locked when you close it.
I would then need to press the second button to release the lower tailgate though if I want that down.
Post #478036 11th May 2018 2:04pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi,
On mine, 2008 SC, it unlocks only the uper tailgate
[/img]
Post #478038 11th May 2018 2:06pm
my 2012 is like Paul's ^^..
press and the tailgate unlocks and jumps up a little allowing you to just lift it to put shopping in etc..
the rest of the FF stays locked..
close the tailgate and it automatically locks and the indicators flash to confirm.. ... - .- -.
Post #478040 11th May 2018 2:19pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
My 2010 upper tailgate lifts off the lock so that you can open it without having to press the micro switch.....
My 2008 didn’t.
I assume the gas struts were starting to fail on my 2008. 2011 TDV8 4.4 AB Bournville Brown
Post #478357 14th May 2018 1:24pm
