![]() | Home > Technical (L322) > "Key not found" fault |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
If you have had this come up, DO NOT let the stealer charge you for a new key. It happens when you put your key on the centre console and the signal is blocked. There should be a RFA software update available.?
