![]() | Home > Technical (L322) > This happened today. |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
This happened today, whilst the other half was using the vehicle.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
How old is the battery? 2015 4.4 AB
Battery is 18 months old, AGM and a Land Rover one, has been faultless even through winter with the pre heat.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Plug your charger overnight and try in the morning before you do battery disconnect. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
I would put a call through to BAS in the morning sir... Pete is very good and helpful... |
Far from an expert but should you have an agm in a 3.6 ? Don't they need a higher charge than the 3.6 can give ? Again , I'm not an expert. 2015 4.4 AB
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
Had some thing similar recently... the ignition switch !! |
Sorted.
Glad you got it sorted |
