Home > Maintenance & Mods (L405) > Adaptive Cruise Retrofit to 2014 L405 Vogue
Page 3 of 3 <123
Silvertonesx24
pherplexed wrote:
Mark1107 - Ans has already completed the installation and just has some questions about a few of the values on the CCF configuration.
Ans – I have not had a chance to reconnect my IIDtool to see if those extra two values have been configured on my spec. I will try and take a look this afternoon.
Are you still getting the park break and cruise control errors? If so, have you tried clearing the faults with the IIDtool to see if that clears it up?
Did you ever check this? Sorry to bump an old thread but I have this exact same issue.
Post #722452 7th Aug 2025 6:52am
Silvertonesx24
Ans wrote:
This is super useful info!
I have connected the new radar today and updated CCF exactly as per instructions described above. I haven’t started the car yet (new steering wheel buttons not installed yet ), however, I am seeing on the dash “parking brake fault” and “cruise control not available” messages. The latter message was expected since I haven’t run the calibration, but the brake related message is somewhat unexpected. did you see something like that during your installation?
On the positive side, the adaptive cruise control calibration option has appeared in the software after CCF updates and also the adaptive cruise dash signs light up when ignition is in position 2.
Also, a comment/question on CCF changes.
There were two parameters that appear to be related to ACC, If judged by name, but were not listed in the instructions above:
-Adaptive speed control ECU: disable (current value)
-Forward collision warning: not supported ( current value)
I haven’t updated these two, but wondering if I need to??? The first one can have value enable and the second one fitted.
The parameters that I did update exactly matched the Above listing of 11settings.
Speed Control: Adaptive speed control is fitted
Adaptive Speed Control ECU: North America, Canada, Mexico, Australia (already had this value)
Adaptive Speed Control ECU: Standard blockage level -40dB (already had this value)
Collision Mitigation By Braking: Fitted
Standard Speed Control Display Type: Adaptive speed control full display plus priority messages
Speed Control: Adaptive speed control with queue assist
Adaptive Cruise Control Indication In Instrument Cluster: Enabled
Speed Control: Adaptive speed control, stop and go
Collision Mitigation By Braking: Collision mitigation by braking GEN 3
Forward Collision Warning: Forward collision warning GEN 3
Front Crash Sensing System: Front crash sensing system - Upfront sensor
If you happen to connect diagnostic software to your car, could check:
“Adaptive Speed Control ECU” do you see 2 or 3 parameters with this name and what are the values in CCF?
“Forward collision warning” (see attachment) do you see 1 or 2 parameters with this exact name and what are the values?
I have this exact same issue. I also do not have those 2 parameters in my Ccf, and have the same errors you had after changing the oyyer ones.
2013 l405 attempting to use sensor from a 2016 Jaguar.
Post #722453 7th Aug 2025 6:53am
Page 3 of 3 <123
