Home > Technical (L322) > Question about brakes
green-oval-nut
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
On my 2004 TD6, I have the red brake warning light on, so I plugged my diagnostics in as the car had brand new pads 3 weeks ago and 1 new wear sensor. It comes up with brake fluid low. So I checked the brake fluid level. It is on the maximum.
Could weak brake fluid cause the same fault message to occur?
Post #479902 1st Jun 2018 5:28pm
kbald
I think the brake fluid sensor works on a float sensor in the top of the resovoir. Coud be an issue with the cable on the sensor. Can you test the feed to it. The system isnt sophisticated enough to measure weak fluid unless im totally wrong! Current 2007 TDV8 Vogue Buckingham Blue
Post #479905 1st Jun 2018 7:21pm
Pawl
Take the reservoir cap off & turn it upside down, so the float contacts the cap.
If the warning light doesn't turn off - either the cap contacts or wiring to it have a fault.
If it does turn off, maybe the float is sticking or faulty (eg is full of brake fluid)
PS it definitely isn't clever enough to know anything useful about the fluid - lol. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #479910 1st Jun 2018 9:11pm
