Home > Maintenance & Mods (L322) > Bubbling on trim around Gear Selector?
mike2013
Has anyone experienced a bubbling of the silvery metallic trim around the gear and terrain selectors on the central console of their L322?
This is in a 2010 4.4 TDV8.
It looks a bit like there’s a metallic film over the part...
To complicate the matter, the replacement part that PowerfulUK sells, seems permanently out of stock!!
Any thoughts would be much appreciated!
Thanks!!
L405 2016 4.4 SDV8 SE
Evoque 2016 2.0d HSE
L322 2010 4.4 TDV8 SE
Freelander 2 2009 HSE
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #480436 8th Jun 2018 3:19pm
not seen that before..
i dont like the sun reflections on mine so i wrapped it in gloss black, not the best of jobs but saves spending £90 on the powerfuluk one and totally dismantling the centre console to fit it..
Post #480438 8th Jun 2018 3:43pm
mike2013
You’ve done an amazing job with that, but I doubt that I would have the skill or dexterity to apply a film so neatly as you have done!!
Do you have a link to the product that you used, please?
Thanks
Mike -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #480443 8th Jun 2018 4:47pm
search 'black gloss wrap' on ebay Mike, there are many listings...
what you see in the pic was a quick job with the intention of doing it properly by removing the panel but the work involved has put me off doing that ... ... - .- -.
Post #480447 8th Jun 2018 5:29pm
nino_nino
same modificacion here Mike but in matte finish, cuts on reflection bit more. it is not very difficult.
Nino,
Post #480507 9th Jun 2018 12:35pm
wrapping it is a decent idea, however as its bubbling up you will still see the raised area unless you flat back the area first.
Never seen one of these go funny there though.... There is nothing that can't be fixed with a hammer😜😜
Post #480524 9th Jun 2018 5:45pm
mike2013
Thanks for the great tips.
You guys have done great jobs with the wrapping.
Definitely food for thought.
Thanks! -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #481024 16th Jun 2018 12:07am
nino_nino
mike2013, use razor blade to cut out buble and nail polish to build up hole to a surrounding lavel. nail polish builds up quick .
Nino,
Post #481036 16th Jun 2018 8:53am
GGDR
Not too expensive if you want to replace it:
https://www.powerfuluk.com/vehicles/range-...nuine.html
. Cheers, Greg
Post #481096 16th Jun 2018 9:36pm
nearlee
Wales
Urrrr double r you might want to read the opening post. Whistle Remember:- amateurs built the ark
Proffesionals built the titanic
Post #481118 17th Jun 2018 6:30am
GGDR
oh missed that!
Maybe try Dan @duckworths then?
You could also send it to wicked coatings, not sure how much they charge but their stuff looks great.
. Cheers, Greg
Post #481119 17th Jun 2018 7:30am
mike2013
Thanks!
Will look into these options.
Mike -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #481126 17th Jun 2018 8:28am
if you do manage to find a replacement or want to wrap it then have a look at this video,
Post #481129 17th Jun 2018 8:46am
mike2013
Thanks Thumbs Up -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #481391 19th Jun 2018 9:49pm
