Home > In Car Electronics (L322) > No radio
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
No radio
Today a stramge thing has happened on my RR
I've tried to turn off the radio and I can“t get it even with the ignition off. Afte rseveral tries it turns off.
Now it wont tur on.
All the functions on the headunit are showing, there is sound on the Bluetooth system but the DSP sign on the headunit is dark. If I go to the trunk and remove the main socket from the DSP and connect it again, the sign DSP it shows on the headunit but after 2 or 3 seconds it goes off
What can be this?
Cheers
Post #477688 7th May 2018 6:18pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Check the pins carefully on the DSP on the connector nearest to you when you open the compartment -- I had two that disintegrated and had to rewire from the pins inside the unit -- mine was intermittent before my fix too
Post #480610 10th Jun 2018 5:50pm
