Home > Technical (L322) > new owner L322 what are best preventive task to carry out
Bronjen
United Kingdom 2002 Range Rover Autobiography 4.4 V8 Baltic Blue
Hi I have a 2002 4.4 L322 with 130K on clock, have been trawling the site for further info, is there a list of preventive tasks I should carry out before putting the RR on the road at the end of month?
These are the Items on my list:
Replacing the thermostat with a lower temp one.
Transmission oil change and flush.
Engine oil change, next diffs and transfer box oil
Flush power steer fluid
Any suggestions on the below items
A. heater blower motor does not work
B. N/s mirror glass angle not correct so cant see the side of car even using adjustment?
C. Rocker covers look ok what parts of PVC system would be best to clean or renew?
D. Would I have a need for an IID tool for a 2002 L322 for future diagnosis, I have also have a base Discovery 3, will IID tool work on both cars?
Thanks in advance
Bronjen Whistle
Post #480881 14th Jun 2018 9:34am
CS
Just on A it may need a new final stage resistor, a well known weakness. Only Range Rovers since 1988
Post #480889 14th Jun 2018 11:04am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I have a 2003 V8 and I’ve found the IIDtool to be indispensable, one thing to check would be the battery as these vehicles are very voltage sensitive and another, which is tied to the first, is to check the alternator output as they do sometimes give up the ghost.
Mine was putting out 13.3v at tickover which at first glance would seem ok but these need an output of at least 14.1 - 14.4v to keep everything running happily, as a result of the 13.3v I was experiencing some odd faults but I swapped the alternator over and it’s been fine ever since.
Good luck in your investigations Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #480890 14th Jun 2018 11:51am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Number one on my checklist is the radiator - the gearbox is cooled by the bottom 9 or so rows of fins on the radiator - if this gets sludged up (which they do) then the gearbox oil cooler also sludges up and prevents the gearbox cooling properly.
B could be the mirror stuck in reversing mode - which happens if the mirror adjust selector is set to passenger and you engage reverse the mirror will dip.
PCV system - check the rubber hoses running along the back of the engine into the PCV valve with the plastic engine cover off - if these are breaking down they will feel horrible and squishy. The PCV valve can also get gummed up - worth replacing if replacing the 2 main rubber hoses (also 2 smaller hoses often need done too) - plenty of info in the wiki as to how to do. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #480911 14th Jun 2018 5:46pm
UK Marine
+1 for the radiator look what I found in mine just after I bought it...
Answers on a postcard please if you know what it is Thumbs Up ______________________________
Simon
Post #480916 14th Jun 2018 7:52pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
IID would work on both but you would need an extra licence for the second vehicle for many of the features. A low cost alternative is the iCarsoft. It's nowhere near as capable (it can only read and clear faults) or easy to use but it's about a fifth of the price. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #480919 14th Jun 2018 9:27pm
stu1
You will need an IIDTool.
Post #480921 14th Jun 2018 9:44pm
Bronjen
Brilliant info just what i needed the car has had a new rad and water pump, however i will defo remove and reverse flush, as i need to replace fan shroud due to a big crack in top corner covered with black duct tape (probably got damaged when the previous owner replaced water pump)
And will look into obtaining an IID tool
Many thanks Thumbs Up
Post #480938 15th Jun 2018 8:17am
dingg1
non compatible antifreeze been added IMO
OAT added to non OAT or vice versa
Post #480942 15th Jun 2018 9:05am
UK Marine
That could be the answer actually because when I drained it down it did have pink antifreeze in, and eurocarparts do sell pink oat antifreeze. ______________________________
Simon
Post #480946 15th Jun 2018 9:53am
holidaychicken
Timing chain and guides if not done already are prone to failure and I believe the LPG converted models fail earlier but that’s just my opinion.
Post #481229 18th Jun 2018 5:43am
