Home > Technical (L322) > TPMS reading too high
Sandyt
Gents the TPMS on mine is reading the pressures on all tyres including the spare 20 psi higher than actual any way to recalibrate ??
Post #481686 23rd Jun 2018 3:04pm
pull the fuse or battery reset... ... - .- -.
Post #481688 23rd Jun 2018 3:24pm
Sandyt
Thanks Stan will have a go
Post #481693 23rd Jun 2018 4:41pm
Sandyt
All sorted switched off with 11d tool then switched back on all good Thumbs Up
Post #481695 23rd Jun 2018 5:21pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Re: TPMS reading too high
Can you see the actual readings or were you just getting warnings? 2012 TDV8 Vogue SE 4.4
Post #481789 24th Jun 2018 8:01pm
Sandyt
No can see the readings
Post #481802 24th Jun 2018 9:56pm
Frans@Yamorna
Thanks!
My son has a 2016 D4 with TPMS similar to the RR system.On the D4 one can see the readings of the individuel wheels,and I was wondering if it is not possible to activate the same with the iid tool on the RRV?There are a few optional settings if one look under TPMS on the tool,so maybe it is possible!Wonder what the setting(code) on these D4's are?Any ideas?
GAP can't help,does not now the meaning of the settings,all in code form. 2012 TDV8 Vogue SE 4.4
Post #481811 25th Jun 2018 6:37am
Sandyt
No idea about the D4 but the system on the Fatty is all self learning and once synced you see readings of all 5 wheels if fitted
Post #481813 25th Jun 2018 8:29am
Frans@Yamorna
Hi do you mean you can actually see the pressure readings?If so can you pass the setting as per your iid tool?My Fattie has TPMS and it alerts when there is a problem but can not see the pressures!Would like to see that if possible.
I think the D4 system is the same.Sensors in wheels looks the same! 2012 TDV8 Vogue SE 4.4
Post #481815 25th Jun 2018 9:03am
Sandyt
Can only see the pressure readings when the 11d tool is connected without it connected just an alert or nothing
Post #481817 25th Jun 2018 9:08am
Frans@Yamorna
Good news of some sort.....at least it reads the pressures and can display it Very Happy Now to find the correct setting to display it in the dash!! 2012 TDV8 Vogue SE 4.4
Post #481818 25th Jun 2018 10:26am
Frans@Yamorna
Where do you see it on iid tool?Best I can see on tool is that the pressure is "OK"!!
Thanks 2012 TDV8 Vogue SE 4.4
Post #481844 25th Jun 2018 3:45pm
