Home > Maintenance & Mods (L322) > Turbo help 3.6
Steveo
United Kingdom 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Turbo help 3.6
Evening all I need some help I believe that my passenger side turbo has gone today on the dual carriageway there was a loss of power and blue smoke coming from the exhaust I limped it off at the next service approx 0.5 miles plugged in my gap tool and got fault code po10c-21(2c) and when the engine was running if you take off the oil cap there was quite a lot of pressure there I now have the car at home and there is a bad oil leak from the passenger side is there any way to check if it is the turbo and can it be replaced with the engine in and is there a guide any where cheers Steve please help I am meant to be going away next weekend in the car
Post #481715 23rd Jun 2018 9:41pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My right and left were done in the car and i had both done at midland turbo who most of my indy mech use by me, and my mech fitted them and the valves gaskets oils , i also put brand new egr valves on which were genuine total all in cost me 2900 for the lot labour oils parts etc which was fair Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #481897 26th Jun 2018 2:12pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
If you use the search function there is someone who did his own turbos with the engine in the car, if i remember correctly he detailed it quite well but did day one side was much easier than the other. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481914 26th Jun 2018 5:13pm
