Home > In Car Electronics (L322) > Flashing stereo power button
dirtymonkey38
The power button on my stereo/nav unit intermittently flashes orange. Doesn't seem to matter what the source is, DAB, radio etc just seems to flash every 5-10 seconds. Does anyone else have or had this issue before? 2011 RR Autobiography 4.4 TDV8
Post #481377 19th Jun 2018 8:36pm
this from our wiki might help,
http://www.fullfatrr.com/forum/topic24270.html ... - .- -.
Post #481379 19th Jun 2018 8:37pm
dirtymonkey38
It all works ok, nothing frozen. just the flashing every few seconds is really irritation. 2011 4.4tdv8 if it helps, different unit from the 2006 model? 2011 RR Autobiography 4.4 TDV8
Post #481385 19th Jun 2018 8:55pm
i've looked in the WM and done a forum search and cant find any relevance to your problem...
i'm sure someone will come along and help.. ... - .- -.
Post #481388 19th Jun 2018 9:14pm
dirtymonkey38
Cheers Stan. I will still check the connections and reseat them see if it does anything, might explain the rubbish bluetooth connection to Iphone though...although i don't have issues with android (bad interference during calls). Probably an apple thing. Also get a very bad DAB reception. 2011 RR Autobiography 4.4 TDV8
Post #481389 19th Jun 2018 9:28pm
nino_nino
Bosnia Herzegovina 2012 Range Rover Autobiography Black TDV8 Santorini Black
,how old is your battery d38. I had the same thing when the battery is low on power.
Nino.
Post #481395 19th Jun 2018 11:16pm
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
From the handbook...
I’m sure you’ll agree that this snippet makes it much clearer 🙄
 Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #481398 19th Jun 2018 11:53pm
dirtymonkey38
Yes, only its not for a short while its constantly flashing, even after driving for an hour. 2011 RR Autobiography 4.4 TDV8
Post #481631 22nd Jun 2018 7:25pm
dirtymonkey38
Is there a way to upload a video? 2011 RR Autobiography 4.4 TDV8
Post #481634 22nd Jun 2018 7:36pm
upload the video to youtube and then post the link it here... ... - .- -.
Post #481638 22nd Jun 2018 8:41pm
dirtymonkey38
Post #481639 22nd Jun 2018 9:05pm
JackRegan
I had a problem with the audio dropping out on my L322 and I think my light used to flash on occasions similar to your video.
Apparently mine was something to do with the digital tuner picking up then dropping signals resulting to it constantly scanning. I was told this was due to the poor signal in the area where I live.
I was sceptical about this diagnosis however as far as I can remember the issue was resolved by changing the digital tv region to one outside of the UK. Whilst I was't able to use the TV without re-setting it back to the UK, it completely stopped my audio dropout problem.
Could be worth a try
Jack 2024 P550e Autobiography
2016MY TDV6 Autobiography
2011MY 5.0 SC Autobiography Black
2005 TD6 Vogue
Post #481643 22nd Jun 2018 9:27pm
just guessing now but try unplugging any usb sticks you have connected and/or do a battery disconnection.. ... - .- -.
Post #481646 22nd Jun 2018 9:33pm
dirtymonkey38
No sound dropping out just the flickering light. Car is completely empty and no usb or audio devices plugged in, although I do usually have a ssd hard drive plugged into the centre arm rest usb. Due to go into a body shop after some tool took my mirror off which is why I’ve emptied it...might unplug the dashcam though see if that does anything. Failing that battery might be on the way out. It just catches my eye and is irritating. 2011 RR Autobiography 4.4 TDV8
Post #481656 22nd Jun 2018 10:08pm
dirtymonkey38
Think I've sorted it Very Happy 2011 RR Autobiography 4.4 TDV8
Post #481697 23rd Jun 2018 6:36pm
