Home > Maintenance & Mods (L322) > The Mysteries of iphone integration/docking
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
My Iphone data cable , stretched it out a bit passed it though the small slot as per your photo from the lower cubby , stays in top section sorted for me Smile Far to many gone...
Post #63402 11th May 2011 11:12am
ds
United Kingdom 2006 Range Rover Vogue SE Supercharged Buckingham Blue
but what did you plug the data cable into ? ds
Post #63403 11th May 2011 11:14am
tboner001
My Iphone ? Far to many gone...
Post #63405 11th May 2011 11:17am
ds
what about the other end ? does your car come with an i-phone connection then ?
tboner001 wrote:
My Iphone ?
 ds
Post #63406 11th May 2011 11:18am
tboner001
Yes and USB for the audio Far to many gone...
Post #63408 11th May 2011 11:23am
jammyk
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Stealer advice on S/W upgrade
OK, so coming into this discssion late. i too have the issue where phone book and pairing issue mean every time i get in the vehicle i have to re-enter the code. When re-paired there are, sadly, no phone book entries or last dialled numbers shown.
The fix is a 'Dealer' software upgrade to thevehicle i have been informed by the sales team. They are working on getting me a price for the update.
Have you chaps got any guideline prices that i should 'expect'? my old M5 e36 had the same s/w upgrade and that was over £200....
did i also read a post that reckoned there was cheaper route by exchanging the phone module iteself?
Post #64528 18th May 2011 5:34pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Wiggs (FFRR Member) does exchange phone modules which are a 10 minute swap and play.
Post #64538 18th May 2011 6:42pm
iceshj
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Wiggs is right. I swapped mine and now connects every time without fail
Post #65938 26th May 2011 8:08pm
ds
iceshj wrote:
SteveMFr wrote:
Hi Gerry,
I assume you meant this?
This is not a dealer option. This is a custom job I did for a friend about a year back in a 2010. It consists of a modified BMW iPhone cradle, a modified RR iPhone/Aux port and the wiring. I could do another, I suppose... I'd have to check on the prices of the bits. Can't remember off the top of my head (I suffer from CRS). Guessing, roughly GBP250. The wiring was all hidden, BTW. Silly to have a squiggly cord running through the middle of the cubby, if you ask me.
Let me know if you're that interested.
Second time I've written that today. I'm going to go into business here. Laughing
Hi,
this is just what I am after. Could you send me all the details etc. What does this setup allow you to do. Can you play the music, charge etc etc. Any info you give me would be fantastic. ease to setup/fit??
Kind regards
Dave
Hi, I have finally back-dated the Software on my Blackberry torch and now this is working fine on bluetooth.
however, i would like to know if you could point me in the right direction of how to install a blackberry torch cradle in this range rover, it's a supercharged vogue se, so it comes with a cradle already fitted in the cubby box, i would imagine it is quite feasable to change this, but land rover are quite useless, so they have stopped making update cradles, can you suggest anything? thank you, david
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ds
Post #66225 29th May 2011 11:41am
