![]() | Home > Technical (L322) > 3.6TDV8 Engine System Fault (weird one!) |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
First time posting here for a few years! |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
Have you checked the 4 short 90 degree hoses under the engine cover for damage?
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
There are also 2 more hoses that connect the turbos to their mounting, they are quite short but maybe a possibility ? 2015 4.4 AB
Thanks gents. The garage have had a camera up the turbo intake pipe and they can see that the blades are not spinning. This explains why the MAF appeared to be reading incorrectly when, in fact, it was obviously right.
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 68 ![]() ![]() ![]() |
OK, best of luck to you!
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
100% recommend getting the EGR's out and inspecting for missing parts. It should be obvious. For the cost of the gaskets, its an easy one to rule out and vital with your symptoms of jammed turbo blades.
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
must be the season for it mines behaving in a similar fashion she drives fine then then i get the engine system failure warning along with special programmes inactive however if i turn it off and back on again it clears and drives fine. I have changed both the MAFs which seemed to cure it for a coupe of days now it's back again and to add to this the rear drivers side brake comes on ?.The brake pipes where renewed a short time ago and it's going back to them tomorrow for a calliper rebuild and diagnostics session and i'm going to get them to reset the ecu L322 2008 vogue
Nothing missing there. Looks to be age/mileage related turbo failure. Second car this month and sixth of the year so far for the garage. Always appears to be the left-hand (n/s) turbo which goes first.
Sounds like it could be the (variable) turbo vanes getting sticky. Get them lubricated, but don't waste your time with the main stealer. Town & County used to secretly send cars down to Mann Automotive in Laurencekirk in order to get the turbo vane lubrication done, because nobody in Aberdeen had the ability to do it and the dealer handbook says it can't be done. Mann developed their own convoluted tool for the job. Anyway, the upshot of all this is the car is getting two new turbos, a new intercooler, new turbo hoses and a new a/c condenser to boot. The bill might be more than the car is worth, but it's worth a hell of a lot more to me than the book value. Here's hoping for another 130k miles! ![]() ![]() ![]() |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
chief64 Member Since: 14 Oct 2015 Location: AALESUND Posts: 21 ![]() ![]() ![]() |
I had the same problem,and when open one of the EGR,I find that valve seat had separated from spindel,and lucky stay inside EGR housing,changed to new EGR,all ok. |
I suppose the answer is 'why not'? ![]() Also replaced the air-con condenser at the same time! ![]() ![]() |
Car now running like brand-new. Left hand turbo was siezed solid. Starts and runs exactly as it did when it was first out of the showroom. |
Adriansj Member Since: 22 Jun 2021 Location: Swindon Posts: 8 ![]() ![]() ![]() |
Hi everyone,
Check for a hairline crack in the plastic air intake manifold on the right hand side. Use soapy water to find it.
