Home > Technical (L322) > Gearbox temp iid tool
dingg1
My iid tool doesn't appear to be able to read gearbox temp in the live value menu , unless I'm missing a hidden menu shouldn't this be one thing that would be there?
Its a non bt version 2007
If it cant read the temp anyone know what android app would enable this using an elm obd2 plug in?
Cheer s
Post #483909 20th Jul 2018 4:42pm
According to the GAP site for your vehicle - Range Rover 2007 - Live Values TCM Transmission
Transmission Temperature is towards the end of the list. I have it on my non BT iiDtool for an '02 so you must have ? .
Post #483914 20th Jul 2018 4:58pm
dingg1
Cheers Joe
I have double checked and even reflashed the tool and no tcm is in the live values menu
I had the gearbox oil changed a couple of weeks ago
and suspect something may have happened then
I'm going to have to email gap I think
Post #483920 20th Jul 2018 5:50pm
dingg1
Excellent response from Patrick at GAP has sorted the issue and all ecus are showing in the live values menu
The after sales service is second to none Very Happy
Post #483971 21st Jul 2018 11:53am
What was the problem ? .
Post #483974 21st Jul 2018 11:56am
dingg1
I don't know tbh Joe , but Patrick assisted with a guide where the tool scans for all ecus and when I went back to live values the tcm was there , unfortunately its lost from the menu again , suspect a comms error either on the car or in the iid tool
Post #483994 21st Jul 2018 4:59pm
dingg1
I still have an issue reading the tcm live values
after lots of assistance from Pat at GAP we came to the conclusion the iid tool I was using was at fault
soooo I wanted an excuse anyway to upgrade to the BT tool and did so , the tool arrived today and I eagerly set it up and fully expected to see the tcm in the live values BUT
NOOO still missing from the live value menu , now awaiting a reply for some assistance from GAP
the thing is the car is driving great with no errors from the gearbox at all (so things could be a lot worse) , just hacked off I cant see the tcm info at all using the iid tool and hope this isn't the start of canbus errors.
Hoping Pat can give me a plan to 'wake up' the tcm or otherwise fault find the problem
Post #484468 27th Jul 2018 7:00pm
dingg1
best update this with the fault that was causing non appearance of gearbox tcm in iid tool menus
after much help from pat at gap and much to-ing and froing with logs from the tool the problem was traced back to my lpg set up , once the lpg system was disabled I was able to view the tcm using the iid tool , and its still there after re-enbling the lpg system . Just a glitch on the can bus system due to aftermarket add ons and nothing to be too concerned about , even though it had me thinking that my gearbox control module was on its last legs at one point Rolling Eyes
Post #487187 26th Aug 2018 4:47pm
