![]() | Home > Maintenance & Mods (L322) > Electrical gremlins due to Light Control Module? |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
So the wife went to work and said the turn signals stopped working. Right and left. I go check it out to find signals not working but flashers were. No sound but they would flash. The first disturbing part was I couldn't find a fuse to check. Couldn't find it in RAVE either. So we switched cars. On the way home I tried the left signal. Nothing then 10 seconds later, with the switch off, it comes on and wouldn't shut off. Then it did. Same with the flashers. Then the seatbelt warning came on. Then off. Then the Air suspension inactive warning. Then off. Finally I noticed the infotainment screen was off and the system wouldn't come on. A few months ago I did the $7 amp bypass on the BM54 and fixed it. Lots of hum from poor grounding but at least I could change my settings.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
I had this intermittently and could not find a solution.
Thanks. I spoke too soon that pulling the infotainment fuse gave me back signals and proper hazards. Went to run to the store and they are still not correct. So maybe bad relay? Back to the wiring diagram. |
I'm believing the problem may be in the LCM. RAVE says needing Testbook 4 to reconfigure a new one. Are these vehicle specific or can I swap in another one from a 2004? |
OK this all may be a big "never mind". In pulling LCM to look for corrosion I first disconnected the battery ground. Well it pretty much came off on its own. For completeness sake I pulled the LCM and found no corrosion on pins or board. I added a couple of lock washers to the ground clamp. At this moment the problem is solved.
Some have just been able to replace the LCM without problems (2nd hand) whilst others indicate some recoding is required (possibly new ones ?)
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
"I first disconnected the battery ground. Well it pretty much came off on its own."
Yes seems to be. Looks like it killed my infotainment screen. Time for an Android unit. |
| mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737
The LCM contains the about 1/3 of all the vehicles configuration, if the doner vehicle is of the same spec and has the sam factory options fitted/enabled then it will work. However you may find that the doner vehicle had different options fitted/enabled and some systems may no longer work on your car until it is recoded.
Thanks folks, I may be back to swapping one out. Wife just texted the signals not working again. My iidtool has shown low voltage errors for the headlights since I purchased both RR and tool about 50k miles ago. This is why I was looking at the LCM. Maybe the loose ground cable was just coincidental.
Current update is that signals worked fine on way home wife says but added she didn't have lights and A/C going so less electrical stress. I'll try it later with lights wipers AC and radio. |
Update: do the following faults point to LCM errors? 0x2A headlight (RL) ignition voltage <7 5 volts, 0x88 I-Bus fault, 0xBE Lightning Control Module error, LCM-Light Control v11, 0xC ECU EEPROM fault. I don't remember the lighting control faults being there in the past. |
Try clearing the faults then (does this fix anything?)
At this moment all is good. I took it out with lights/wipers /AC/hazards /radio. No issues. Checked live battery voltage -13.9. I will go clear them. I know the list was holding the left signal bulb out fault. I replaced the bulb just before this all started. Hmmmmm. |
| All times are GMT |
