![]() | Home > General > Running in |
HJD Member Since: 09 Feb 2011 Location: High Leicestershire Posts: 22 ![]() ![]() ![]() |
Starting to think about actually having the beast now (2 weeks to wait).
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
any new car should be treated with respect ..new toys to play with ,different handling etc..i would enjoy the pleasure of having a new FFRR and cruise gently down the road and let everyone think 'lucky bar-steward'... |
As per Scarey, just treat her with respect.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
I had heard once ( long time ago ) that if you drive is soft at first it will always be quiet but not the fastest, and conversly if you drive it hard at first it will always be a quicker car (for its type) but noisy.
Thanks Guys. All good advice. MY2011 FFRR 4.4 TDV8 Vogue, Santorini Black and Ivory *Arrived*
And it worth remembering that engines are designed to rev within the parameters specified. toodling around below 3k rpm all day is not necessarily beneficial at all...
scene247 Member Since: 16 Sep 2010 Location: London Posts: 126 ![]() ![]() |
When I picked mine up was told no running in required for new cars anymore. That said was also told to respect the brakes, let them bed in and don't slam them on to start with. Also new brakes are less effective than part worn - give it 500 miles. Oh and the heating/cooling of discs makes them harder, maybe abuse of new ones is the reason I've seen a few posts on warped discs? Who knows.
Japseroony Member Since: 18 Nov 2008 Location: North East Posts: 423 ![]() ![]() ![]() |
Just get on and enjoy the new engine/gearbox and give it some freedom when you can |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
always divided this one.
Labour on the engine is "High Gear Up Hill" |
yes i mean avoid high gear up hill. put you foot down a little and it will drop a gear. 2004 black Vogue TD6 |
Gotcha |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Rev it till it rattles... it'll be in the workshop anyway in a few months |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Modern pistons , you have got the first 200 miles to bed them in and then you have got what you have got , i was told to get them warm and then use the full RPM range over 2 runs IE 100 mile runs, Heat cycles the engine and creates a piston to liner seal at TDC. Remember all the modern cars are put on a roller check and given full bore to check for leaks and power outputs as they leave the line. Far to many gone... |
