![]() | Home > Maintenance & Mods (L322) > Rear light change ????? |
Does that price include the two circuit boards and the new grommets required? You will have to drill some holes and grind off some sticky out bits.
andyfid Member Since: 10 Apr 2016 Location: barnsley Posts: 104 ![]() ![]() ![]() |
I already have the boards and grommets 👍 had them a while I got the boards when the lights were playing up but turned out to be the bloody dsp,bm54 and Lcm that had water damage and causing battery drain 🙈🙈 |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
What boards do you have? The early ones still required extra resistors to stop the hyper flash. Powerful’s newer boards seem to have fixed the need for the extra resistor.. the disco lights can be resolved by turning off rear bulb monitering 👍 |
That’s the newer ones. All good then 👍 |
