Home > Technical (L322) > Steering Tilt not working...
Danwilderspin
Since owning the car the tilt has never worked - telescopic is fine no tilt. I don't even get a noise when trying to get a tilt.
Is there a common diy for this fault?
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #485311 6th Aug 2018 3:47pm
verydisco
Yes and it has been covered here, it is quite common indeed.
Just check with the Search icon, you'll find it Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #485312 6th Aug 2018 4:00pm
Danwilderspin
I have found it in multiple places but they all seem to mention the motor is still wurring but mine makes no noise... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #485313 6th Aug 2018 4:02pm
verydisco
I see.
Check fuses, just in case. If everything is fine there, you could unplug the motor and test is with a 12-volt voltmeter to see if it is fine or not. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #485314 6th Aug 2018 4:50pm
Danwilderspin
ok didn't think fuse that would be way too easy Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #485315 6th Aug 2018 4:51pm
Pawl
It could be the connector under the shroud that's been disconnected because of a fault.
I made the mistake of reconnecting ours while sat in the drivers seat with the key in the ignition.
The steering wheel powered down until I was pinned to the seat before I could reach back & pull the connector loose again Shocked
I think the nut / sleeve on the end of the adjustment thread slips - so the motor loses track of where it should return to after lifting up as you get out.
Until I can be bothered to sort it out, the connector is staying dis-connected after optimising the position. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #485327 6th Aug 2018 7:12pm
