Home > Technical (L322) > Fuel sender calibration
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Hi
Do the fuel senders and fuel gauge need calibration when either are replaced?
I had my senders replaced last November by the local stealers as one had failed. I don't normally neck the tank as I only really use the rangie once a week. However I have recently needed to travel to Edinburgh so filled the tank (necked it)
After about 20 miles I noticed the gauge was visibly under full and after running the tank down to 10 miles range it only took 90 litres and I got about 50 miles less out of the tank than I expected.
It seems to me that the senders were not calibrated correctly to the gauge when replaced. Before I go and tell the stealer to fix it. can the senders and guage be calibrated? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #485488 8th Aug 2018 8:48pm
Sounds about normal.... .
Post #485494 8th Aug 2018 10:17pm
