Home > Technical (L322) > Front parking sensor wiring
j_rov
All 4 front parking sensors have stopped working at the same time. I've inspected the plug on the bumper and it's ok, still connected, dry etc.
I've checked at the Parking Aid Module end and it's all dry and looks normal.
Are there any other joins I can check between the front bumper and boot?
The rears work fine still.
Thanks
Jon
(2010 model year) __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #485648 10th Aug 2018 5:40pm
If one sensor goes down, it takes the rest with them (well at least it did with me) and this was a broken wire on one of the sensors
Diagnostics should tell you which one is causing the problem, if an inner one most likely front bumper cover will have to come off, you may be able to get at the outer ones by bending back the wheelarch liners. .
Post #485651 10th Aug 2018 6:11pm
j_rov
Thanks Joe, pretty sure the wiring is ok to the sensors, had the bumper off to check.
IIDTool reports all 4 down. __
Land Rover History:
1976 Series 3 2.25
Post #485652 10th Aug 2018 6:16pm
