Home > Maintenance & Mods (L322) > What spec power steering fluid
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi, can someone tell me which power steering fluid/oil I require to top up my 2008Tdv8 please.Usual conflicting advice abounds,so hopefully I'll get a definitive answer here.😉
I have loads of CHF11 fully synthetic hydraulic fluid which is a green colour,I know some Manufacturers use this for steering,suspension, etc but not sure about Land rover. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #485745 11th Aug 2018 8:24pm
i think its red stuff...have a look at yours and top up with the same colour.. ... - .- -.
Post #485750 11th Aug 2018 8:37pm
From the Owners Handbook:
Texaco Cold Climate PAS Fluid 14315 (UK)
http://www.texacobaltic.eu/en/products/car...fluid.html
eBay:
https://www.ebay.co.uk/itm/Land-Rover-ACE-...1815863341 .
Post #485751 11th Aug 2018 8:41pm
Rapiscan
Thanks, didn't fancy taking a risk mixing what's in with stuff I have unless I knew it was ok. I'll buy Texaco. Cheers. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #485758 11th Aug 2018 8:53pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
It should be a bright yellow / green colour. I bought Ravenol from Advanced Factors and tried the 'siphon out and replacev method but the old fluid was a reddish colour and I noticed the pump starting to make a noise. I assume there was some residual old fluid in there mixing with the new. So I then did a proper flush with more fluid form AF but they no longer sell the Ravenol stuff. Very messy but it worked. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #485790 12th Aug 2018 9:53am
nino_nino
Rapiscan, I am using CHF 202 and it works fine. read my post on vacuum flashing power steering.
http://www.fullfatrr.com/forum/topic47852.html
Nino,
Post #485793 12th Aug 2018 10:35am
