Home > Maintenance & Mods (L322) > How to Enable the Service Indicator ?
Pawl
The Service indicator doesn't work on our 2006 tdv8 - ie no warning of miles to the next service.
I can see the distance using an IID tool (approx 12,000) , but can't find any option on the IID menus to enable / disable the indicator from the message centre.
I've Googled the issue, but no obvious answers come up - unless I'm misunderstanding what the option might be called.
Before servicing the car late last year - after purchasing it with what appeared to be an overdue service requirement, there was also no apparent service indication ( although I didn't use the IID tool at the time to check the mileage to the next service (didn't know how at the time - lol)
Any suggestions how to turn it on ? Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #485982 13th Aug 2018 6:37pm
Pawl
No responses so far & no luck via Mr Google !
Via my IID tool I've finally found under "Live Values" > Instrument Pack that if I try to view the Service Indicator I get the message "Service Indicator Inactive" suggesting there ought to be some way of making it "Active" !
I've tried all of the IID tool menus - but nothing relevant found .
Does the extra info, remind anyone how they've made the Service Indicator "active" or "inactive" or can point me in the right direction ? Paul,
Post #493907 28th Oct 2018 6:00pm
Not sure mine ever told me how long until the service except just before it was due. There is nothing that can't be fixed with a hammer😜😜
Post #493911 28th Oct 2018 6:26pm
Pawl
double post deleted ! Paul,
Post #493914 28th Oct 2018 6:53pm
Weegie
+1
The post 2005 FFs only show when it is due. John
GAP iiD BT-Sold
Post #493922 28th Oct 2018 8:04pm
Pawl
I'm assuming that "Service Indicator Inactive" means that it won't warn me - even when due.
Certainly I got no warning when I originally bought it & the previous owner appeared not to have had it serviced for more than 18 months. Paul,
Post #493933 28th Oct 2018 8:44pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Do an oil service every 12 months whatever and you'll be safe , fuel filter's a good idea too and for the price of an air filter bung a new one in , it'll pay off in the long run .
Post #494211 31st Oct 2018 3:29pm
