Home > Maintenance & Mods (L322) > Front air suspension
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
The beast appears to have a leak from the N/S/F suspension. After being left overnight, this corner is on the bump stop.
Can I replace just this one or should they be done in pairs. I realise that if one has gone, the other may not be far behind but I would prefer to spread the cost out a bit..
Post #486079 14th Aug 2018 2:45pm
replacing in pairs is preferred but to spread the cost ,buy one now and put aside the cash for the other for if and when it goes.. ... - .- -.
Post #486082 14th Aug 2018 3:18pm
mjdronfield
Need to do in pairs. They are springs. I wouldn’t want to mix old and new on one axle, but that’s maybe just me.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #486083 14th Aug 2018 3:21pm
CS
When one of the front air bags on my 2004 car tore on the dealer workshop lift they just replaced that one and the other side was fine for the rest of the time I had the car, a couple of years from memory. That led me to conclude that the requirement to replace both metal springs on the same axle did not apply to air springs. It certainly would do no harm though to check the bag on the other side for perishing or other deterioration in case it is cheaper to do both at once and the other one is on the way out anyway. Only Range Rovers since 1988
Post #486085 14th Aug 2018 3:28pm
