![]() | Home > Off Topic > WIFI DUEL ROUTER ADVICE |
| Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174
It's nice to see there are still some constants in life |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
I only nneed the product they can go...... |
| diesel Member Since: 10 Jan 2011 Location: Wakefield Posts: 41
Get them to price match Amazon |
will try |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
If you are going to add a second wireless router, make sure you set it up with a different subnet for dhcp, or turnoff dhcp and only allow specific IP addresses for specific devices. Things can get messy if you have two routers on the same subnet serving up the same range of IP addys. Security is important, so WPA2 at least, and for double strength control via MAC address too.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Got two sets of those Gaz in my setup along with two broadband packages one from sky broadband and the other from 02 broadband as i have the same problem with coverage ... |
Ok I got the Netgear AV 200 and am about to set it up..... |
OK it took 5 minutes from out of the box to fully working in the previously dead zone of the house! Most impressed and the signal seems excellent.
| bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208
good news...they are pretty plug n play, certainly not cheap but often easier than running new cable everywhere ! cheers
Only concern seems to be that the new access point is open and does not require password following set up as advised? |
Only two problems are:
| ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520
For the Belkin router, trying deleting the connection and re-adding it. Paul
On the Tablet Android 2.1 os I did this - you click "Forget this connection" but scan immediately finds it and adds it again you click connect then obtaining IP Address and failure. Worked fine before I added the new Extender connection.
generally when using mulitple wireless access points to cover an area there are some simple rules to follow:
