Home > Maintenance & Mods (L322) > Well started the maintance (photos ) completed
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Well my RR new to me came with a full history but my experience with land rovers is don't believe anything unless you see it done or do it yourself
So today's plan was
1, engine oil and filter
2, diff oils
3, transfer box oil
Used ramps and raised the suspension for better access
Started with the engine oil and filter , no real problems it's a bit messy but what oil change isn't
Now all done the oil light goes out almost immediately on start up - happy there
Next because it's right next to the sump the front diff , once again no real problem it's a bit tight getting onto the drain plug but a short extension cures that ,then rain stops play so tomorrow it's the transfer box and rear diff , I will be lifting the rear end for that with ramps again for better access
So here's what came out of the front diff
It was dark but the magnet only had sludge on so I think that oils been there a while especially when you see the colour it is when new ( hard to see but at the bottom of the bottle ) looks black in the photo but it was dark brown
So I am expecting the transfer and rear diff to be the same
Gearbox was done with new oil and filter but I am tempted to redo that as well , will add more as and when it's done
Cheers henda
Post #486905 23rd Aug 2018 12:05pm
Henda
Better day today so transfer box oil and rear diff done
Transfer box isn't a hard job , clean all around the the drain and fill plugs
Release the fill plug first drop the oil let it drain refit plug with a new copper washer refill with about 1.5 ltrs of special fluid allow over fill to drain refit plug and new washer
Here's what came out
Not a pretty site
Now the rear diff a bit rusty so wire brush ans wd to clean , then as before fill plug first drop the oil and refill well pleased now all the oils have been done
Here's what came out of the diff
Don't know why there upside down these photos but as you can see there's some dirty oil but the magnets only had sludge so that's them done for awhile now
Done all the work on the drive using ramps and suspension to get better access
Cheers henda Thumbs Up
Post #487011 24th Aug 2018 1:40pm
GGDR
Nice work, worth doing!
. Cheers, Greg
Post #487014 24th Aug 2018 2:23pm
Henda
Cheers mate there's nothing hard there engine oil a bit messy but knowledge that it's done is great
Post #487017 24th Aug 2018 3:31pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
I didn't think it would take you long to get your hands dirty Laughing Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #487026 24th Aug 2018 5:48pm
Henda
Hello dan I was itching much easier than the disco had a good luck under only needs underseal very little rust on the chassis new air tank cv boots new slider brackets so fingers crossed , got wrong off hwmbo "there's house jobs to do" but that's not the first or last time Rolling with laughter
How's yours going Thumbs Up
Cheers henda
Post #487038 24th Aug 2018 7:38pm
Hairy Dan
Mine has been faultless so far, the only thing I miss from the Disco is the remote FBH or I will when the weather gets colder, I've enabled timed climate on it but it comes up with an error and it's not really cold enough to test if it will still work with the error in place. Apart from that I love it and so glad I made the move from the D4 Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #487044 24th Aug 2018 8:12pm
Henda
Makes me smile every time , haven't tried my climate control yet but I'll let you know Thumbs Up
Post #487047 24th Aug 2018 8:18pm
