![]() | Home > General > RA GE ROVER |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
its quite easy to put a coat back on.... |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I would say the correct way is to replace the whole badge but if it was mine, I would clean up where the letter was on the car and the adhesive behind the badge itself,, then apply some body adhesive tape of the same thickness to the back of the badge, then use a sharp knife to trim it before re applying it.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I used number plate double sided from halfords when i pinged mine off. Clean out the old, place over the new then use a craft knife to trim using the lip as a guide. (if you turn it over you'll understand what i mean) Affix on the sun stained spot and job done. Ian |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
If you buy the full set of letters they are mounted on a card that is preformed/cut to make positioning correct on the production line. IIRC forum sponsor DCC 4x4 sells the letter sets 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
I'd say leave it as it is. Might make a few people move out of the way |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
Thanks for the input, I'll try some adhesive today and if that doesn't work, ill get some new.letters |
Adhesive |
Got some vehicle adhesive pads, hopefully this will do the job |
