Home > Technical (L322) > Towing electrics
Infiltrator
United Kingdom 2010 Range Rover Vogue TDV8 Bonatti Grey
Towing electrics
Hi everyone.
First post. Had LR's for years starting with a Ninety TD, followed by a succession of Disco 300TDI, Disco 2 TD5.and then a Disco 3 TDV6.
Just taken the plunge for a 59 plate RR vogue TDV8 and I love it. What a beast. I thought the Disco 3 was good to drive, but this is a whole other level.
Over the first few days thought the drivetrain was quite "lumpy" at slow speeds....especially on the overrun. It stopped if popped into neutral. Had a megaflush on the box and all seems good again
Next job is to put a tow bar and electrics on.
Have the genuine 13 pin electrics and, following the instructions, they tell me to plug them in to a connector in the spare wheelwell.
Of course, nothing is ever simple for me. I don't seem to have a connector to plug into.
Am I looking in the wrong place? Is it hidden somewhere to pull out?do I need some sort of ecu/loom? Multiple searches seem to just tell me that the facelifted models don't need anything else apart from the exterior kit.
Any help would be very much appreciated.
Post #487210 26th Aug 2018 7:02pm
AJGalaxy2012
Im new to L322's as well, I've just redone all of my towing electrics, the plug on mine is towards the nearside of the spare wheel well clipped to the vertical re panel.
 BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #487213 26th Aug 2018 7:35pm
Infiltrator
Thanks. I certainly can't see mine. I'll have to have another look tomorrow. Deffo starting to think I don't have one though.
Why does it always happen to me?
Hurumph.
Post #487223 26th Aug 2018 9:01pm
AJGalaxy2012
Maybe the towbar module isnt installed?
This is how mine looked!
 BMW i3 Electric Car
Post #487226 26th Aug 2018 9:05pm
GGDR
AJGalaxy is that heat damage to your plug? (Aside of the mud) And heat damage to the cable? Or chaffing?
Looks weird..
. Cheers, Greg
Post #487230 26th Aug 2018 10:03pm
Infiltrator
Been out in the rain.
Might it be tucked up if it's never been used?
Found this plug...
.but don't want to go tugging if its a connector for something else.
Thanks
Post #487232 26th Aug 2018 10:25pm
AJGalaxy2012
Yes that’s the one. BMW i3 Electric Car
Post #487242 27th Aug 2018 4:58am
Infiltrator
Yay....thank you. Smile
Post #487260 27th Aug 2018 12:20pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
So, now I know where the plug is, I was wondering if there was such a plug, I thought there would be as range rovers and horse floats seem to go together
So, my question is, dose the plug have the wiring for electric brakes RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #487265 27th Aug 2018 1:32pm
knares
just looked on ebay, over $A300 RR 2005 4.4 petrol
Post #487267 27th Aug 2018 1:45pm
AJGalaxy2012
It only has a brake light signal i.e. on / off, not sure what signals your electric brakes need. BMW i3 Electric Car
Post #487271 27th Aug 2018 2:29pm
knares
thanks, what kind of brakes do trailors have in the UK RR 2005 4.4 petrol
Post #487332 28th Aug 2018 1:44am
AJGalaxy2012
Mechanical over run brakes. As the vehicle slows down, the coupling compresses and that applies the brakes. BMW i3 Electric Car
Post #487334 28th Aug 2018 6:06am
knares
Thanks
Is that hydraulic or wire RR 2005 4.4 petrol
Post #487346 28th Aug 2018 10:48am
Most are cable - there’s is a requirement for the trailer to have a cable or rod handbrake, so it’s easier to use the same cable for the main brake.
I have an American boat trailer with hydraulic brakes and that seems a much better system, albeit I have no handbrake
Post #487348 28th Aug 2018 11:25am
