![]() | Home > Technical (L322) > It never just rains... |
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 ![]() ![]() ![]() |
Good luck indeed mate, I do love our RR but they are mighty testing at times......... |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Well, step one of the plan completed. |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Euro Car Parts do an exchange Lucas alternator - was about £130 for my TD6 which I thought was quite reasonable. Not a bad job to do - couple of hours.
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
If you lift the cup holders out there is a little panel. Remove it and pull the red rape. That will disengage the gearbox from park so it can be moved.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2755 ![]() ![]() |
6-speed box should have a white tab below the right rear corner of the selector mechanism that has to be moved/held (up IIRC) to allow the lever to be pulled out of park. The red tape is for the 8-speed box. |
Steps 2 & 3 completed - battery holding charge
Double post...sorry |
That sounds very cheap! Has he done a TDV8 alt before? If not check, check and check again sir!
The £360 is the labour cost. So six hours at £60/hr.
Step 4 completed.
